580B limited gear shifter movement
crh
03-11-2003 09:58:05
My 580B is about 30 years old and the gear shifter only moves between 1st and neutral. I have tried to remove the shifter cover, but it only comes up about a 1/2". How can I get this cover off, and if it is not obvious, what should I look for.
Thanks,
crh
scottAR
03-12-2003 18:30:24
 Re: 580B limited gear shifter movement in reply to crh, 03-11-2003 09:58:05
My 530 did that one time and it had a reverse shifting fork bent. But you probably have a shuttle and no reverse fork on the main stick. Might be another fork.
Max
03-11-2003 19:03:37
Have you tried pulling the snap ring on top of the shifter in the tower? If not, pull the boot up, pull out the snap ring, select neutral and then remove the shifter and look in and see if the selectors are lined up, if not, line up with a screw driver and then you should be able to lift the cover straight up and find the problem more easily.
crh
03-11-2003 20:55:36
 Re: Re: 580B limited gear shifter movement in reply to Max, 03-11-2003 19:03:37
I had already removed the snap ring, and pulled the shifter out. I haven't tried lining up the selectors with a screwdriver. I'll give it a try in the morning. Thanks, crh
