1410 Won't Start
kydavid
03-14-2003 19:12:48
Just did some work on my 1410. I did some engine work, started it, ran great. Did some extra stuff and changed the oil in the injector pump cam box. Now it won't start. Will run on ether.
Any ideas if pump or injectors? Both are only 3 yrs (500 hrs) old. I am getting fuel to my injectors.
Elmer
03-15-2003 15:26:11
 Re: 1410 Won't Start in reply to kydavid, 03-14-2003 19:12:48
You got yourself a strange problem there. Did you try to push in the cold start valve on the pump. If your getting all kinds of spray at the injectors it should start. But maybe your not building pressure to open the nozzles.
kydavid
03-15-2003 17:05:31
 Re: Re: 1410 Won't Start in reply to Elmer, 03-15-2003 15:26:11
Don't know yet about the actual pattern at the injector. Got fuel going to them but unsure of quantity. Figure I'll pull them and hook them to a fuel line on the pump to see what kind of spray is coming out. I changed cambox oil and all I can figure is either a little oil got in the lines and is stopping up injectors, or pump is toast and pulling the oil out is keeping the tappets from buliding up.
DAB
