Case 580 CK backhoe, Need Info parts
Rich Benjamin,J
03-15-2003 06:33:59
I have a Case 580 CK gas backhoe. The front spindle bushings are worn through to the axle. I was wondering if anyone had a fix for this or if a used axle would be the way to go. What used axles would fit? If you know where I can find one let me know. The engine is also ready for a rebuild and I was curious to know what other Cse tractors share the same engine with the Case 580? Are 530's the same?It has shutlr shift, are the back of the cranks the same on standard shift? Thanks for your help, You can email me directly at intow@msn.com I am in Monticello, NY 12701
Marc
03-15-2003 20:08:50
 Re: Case 580 CK backhoe, Need Info parts in reply to Rich Benjamin,Jr, 03-15-2003 06:33:59
Rich,
Follow the link provided far a parts illustration that includes the "axle repair ends", bearings, spindles, steering arms and rod ends.
Retuen to the Index and click on Engine to see the engine overhaul kits available.
Thanks for looking
Good luck, Marc
Jason
03-15-2003 15:35:37
i have an engine that would fit it, and i might also have an axle. if you are interested let me know
David Elias
12-20-2005 16:48:03
 Re: Re: Case 580 CK backhoe, Need Info parts in reply to Jason , 03-15-2003 15:35:37
You have an engine?
