870 pto
pat harper
03-16-2003 08:29:06
I just bought an 870 and the pto turns all the time. any thoughts on this?
Jim Handke
03-19-2003 06:17:10
 Re: 870 pto in reply to pat harper, 03-16-2003 08:29:06
The pad is indeed worn or the pad holder is broken. We found that problem last year in a 70 series. The first clutch pack housings were perfectly round inside. The newer housings were made a little thicker on one side, so it's elliptical and the pads do a better job of stopping and last longer.
Shane
03-16-2003 08:42:21
Most likely the brake pad on the pto is wore out. Should be cheap and easy to fix.
John Saeli
03-16-2003 13:13:27
 Re: Re: 870 pto in reply to Shane, 03-16-2003 08:42:21
Shane; Isn't that brake adjustable like the earlier tractors? That's assuming that hyd. pressure isn't going to the clutch pack for some reason. John
Shane
03-17-2003 03:30:48
 Re: Re: Re: 870 pto in reply to John Saeli, 03-16-2003 13:13:27
I believe that it is supposed to be automatically adjusted as it wears. But if it is wore too much then it won't work anymore.
