730 hydrolics
Ron
04-07-1999 18:33:38
The last time I tried to pull a haybine with my case 730 the hydrolic system would not lift the cutting head. I checked the pressure and it peeks out and around 800 lbs. Is my problem too little pressure? I see a plate below the power take off shaft where I suspect there may be a filter. Could a clogged filter be the problem? I think my pump must be o k since I am getting pressure. Does anybody have any experience with these? Thanks
