Case 310B Loader/Backhoe Carburator ID
Rick from Paso
03-17-2003 22:50:50
Anyone out there know what model Marvel Carb I have on this tractor, according to my IT manual it's either a TSX680 (for Low cost 310B?) or a TSX635 for the non-diesel 310B. Is the utility tractor supplied with the TLB considered a "Low cost" 310B since its a utility tractor with a non-adjustable front end, no pto and no 3pt? I need to rebuild this carb, what indications are there if it's beyond a rebuild? Thanks so much for your help!
Skip
05-18-2003 18:52:55
 Re: Case 310B Loader/Backhoe Carburator ID in reply to Rick from Paso, 03-17-2003 22:50:50
make sure you remove the high speed needle Before you seperate the carb halfs
Mike Johnston
03-18-2003 09:26:15
I rebuilt a TSX-635 on a 210B last week. There should be a dime sized brass tag that is pinned to the body of the carb. Mine was on the inbound side, next to the block. I used a mirror to view the tag and verify the model before pulling the carb off and ordering a kit.
Not sure about the Low-Cost tractors, or what that means.
Mike Johnston
Rick from Paso
03-18-2003 19:54:11
 Re: Re: Case 310B Loader/Backhoe Carburator ID in reply to Mike Johnston, 03-18-2003 09:26:15
Thank you, I see it too is a TSX635!
