Case 448 Stalling enegine problem Need help quick !
Elvin
03-18-2003 04:11:23
My Case 448 runs good but,as soon as I go up a grade it starts to stall.I had it to the repair shop and they can't seem to find anything wrong. I am very disappointed in the Case.I always dreamed of owning this lawn tractor but now I am ready to get rid of it.
JR REBUILDERS
10-01-2006 14:38:48
 Re: starter out on DB 995, any source for good dea in reply to TimS, 05-24-2006 12:41:49
Hello Jeff, I can help you,e-mail me and let me know if you have the old one.Irebuild on farm equipement. THANKS,JIM
Ray Szerszen
01-15-2004 10:40:20
 Re: Case 448 Stalling enegine problem Need help qu in reply to Elvin, 03-18-2003 04:11:23
I have the same tractor (case 448) that needs to be tuned and fired up.Does anyone know the estimated value of this tractor with deck once I get it running?Average condition I guess.
Ray
Max
03-18-2003 19:10:14
 Re: Case 448 Stalling enegine problem Need help quick ! in reply to Elvin, 03-18-2003 04:11:23
Depending how its stalling out, you may also check the fuel float level in the carb. Has it been tuned up lately? It may be in need of new plugs and timing check.
bob
03-18-2003 06:25:14
Does it just quit outright, or start to lean out and eventually die. The fuel pump diaphram (in the carburetor) may be drying up or leaking on you.
nathan k
08-29-2004 17:11:32
 Re: Re: Case 448 Stalling enegine problem Need hel in reply to bob, 03-18-2003 06:25:14
I was doing some research and came across this forum. I have the same tractor doing the same thing...I was wondering if you found out what was causing it.
Thank you.
