Bent push rods
Tony
03-20-2003 11:11:33
When I got my SC I was told it would run but poorly. I pulled the valve cover and found both push rods on #3 cylinder bent. I pulled the head and all looks okay. I'm going to take the head into a head shop for a good inspection anyway.
I pulled the oil pan and everything looks good here too.
Are bent push rods common for SC's? If so I'd like to know the cause.
Thanks, Tony
C. Amick
03-20-2003 14:10:57
 Re: Bent push rods in reply to Tony, 03-20-2003 11:11:33
Stuck valves and lack of lubrication to the head will also cause it. Run the tractor a little before you put the valve cover back on to make sure oil is getting to the head and to all the rocker arms.
david
03-20-2003 13:26:23
Just went through this on my 1410, a little squirt of ether was all it took to bend both on #4.
CASEPOWER
03-20-2003 13:05:02
They bend from stuck or sticking valves. Have the shop do a valve job and check the head. Put it back on and run it for another 50+ years. it's a Case.
