Case D series grain drill questions
JM
03-23-2003 18:29:51
I have a Case D series grain drill that I'd like to seed some hay ground with. But, I've got some bad bearings in the discs. They are double disc openers. My questions are where can I get bearings and what are their part numbers? Our local dealer doesn't have a parts book so thier not much help. Next question is how do you get the bearing out of the hub, just cut the rivets and rerivet it once the new bearing is in?
John Saeli
03-24-2003 05:36:17
 Re: Case D series grain drill questions in reply to JM, 03-23-2003 18:29:51
JM; Yes; you cut the rivets, replace the brg. and re-rivet, or bolt it back. The bearings are very common, 5/8 bore I'm sure. I've got much of what you need, but I'm sure you can get what you need locally. Hope this helps; John
