Case 200 timing
poncho
03-24-2003 18:11:39
Can anyone give me the points gap, and ignition timing procedure for a Case 200?
Mike Johnston
03-25-2003 07:22:31
 Re: Case 200 timing in reply to poncho, 03-24-2003 18:11:39
Points gap is .020". Firing order is 1-3-4-2. Plug gap is .025"
Set number one cylinder at top dead center on compression stroke. Stab distributor with the rotor in the number one firing position. Rotate the distributor until the points are starting to open. Tighten distibutor clamp. This will get you close. There is no (or very little) advance at idle.
I'm working on a 200 also.
Mike Johnston
ponch
03-31-2003 04:29:56
 Re: Re: Case 200 timing in reply to Mike Johnston, 03-25-2003 07:22:31
Found a plug, rt. side of tractor, that exposes the flywheel and timing marks. A pointer type reference mark makes this a no-brainer!
