730 maintanence trans fluid/filter replacement
country girl
04-09-1999 07:27:47
I need to replace my trans fluid (milky) as well as my filter. Does anyone have any good hints to keep in mind when I'm doing this? I would also like to locate a maintanence manual for my 1960's 730. Does anyone know where I could find one? Thanks.
CASE BOY
04-09-1999 12:54:39
 Re: 730 maintanence trans fluid/filter replacement in reply to country girl, 04-09-1999 07:27:47
You can get away with washing out your filter providing it's not busted.
use reguler hydrualic fluid or CASE IH hy tran you may need to do this a few times to clear it up because when you drain out the CASEing there will still be fluid in the torque.
(just change,run,change,check)
Manuals jen sales
you can do a web search to find him
Cheap
04-10-1999 12:28:15
 Re: Re: 730 maintanence trans fluid/filter replacement in reply to CASE BOY, 04-09-1999 12:54:39
Wash out the filter? How cheap can you get?
Yo
04-11-1999 16:03:45
 Re: Re: Re: 730 maintanence trans fluid/filter replacement in reply to Cheap, 04-10-1999 12:28:15
That comment was a bit of a low blow. That filter on my 930 is a reusable filter. Not sure about the 730 but unless you know for sure these comments are not constructive.
Shaun
04-12-1999 00:31:08
 Re: Re: Re: Re: 730 maintanence trans fluid/filter replacement in reply to Yo, 04-11-1999 16:03:45
I would have to agree my CASE IH dealer informed me that these are reusable filters unless they crack or break
I have spears justin CASE
