1410 Lift Arm Creep
kydavid
03-25-2003 19:03:19
Lift arms on my 1410 creep up, lever creeps too. It goes all the way back and then here the bypass open. Get som fluid leak out of a "weap hole?" in the remote block. Any ideas or suggestions? Thanks all!
Elmer
03-26-2003 15:54:50
 Re: 1410 Lift Arm Creep in reply to kydavid, 03-25-2003 19:03:19
The brake on the lever needs to be adjusted. There are two jam nuts at the bottom of the lever where it pivots. Unjam them and adjust it so the spring at the rearward end of travel will return the lever and still hold it in position.
