Case Eagle hitch
Larry L. Hough
03-26-2003 04:08:42
I have a Case VAC(1950) with the Eagle hitch,The top rod is missing ,can any rod be used or is it a special one. If anyone has picture of a complete hitch please e-mail me one.
mj
03-26-2003 17:44:04
 Re: Case Eagle hitch in reply to Larry L. Hough, 03-26-2003 04:08:42
The problem with the Eagle toplink is that it uses a Cat. 2 pin on the tractor end and a Cat. 1 on the implement end. You can use a Cat. 2 toplink and use a standard bushing to reduce the implement end or use a Cat 1 with bushings on the tractor side with a grade 8 bolt for a pin. Still, the toplink will be too long as the Eagle hitch is very short-coupled so you will have to cut a standard toplink down to fit or lengthen the draft arms by about 3-4 inches.
