1570 or 1370
redwall
03-27-2003 05:43:22
What is the difference between the 1570 and 1370 (white) tractors ? I'm looking at a 1570 and it looks huge. Any suggestions or things to watch for? I am new to Case, so any help or information would be great. Thanks
Allan C
03-28-2003 19:51:05
 Re: 1570 or 1370 in reply to redwall, 03-27-2003 05:43:22
They're much the same tractor. The 1570 engine is just wound tighter. Not as durable maybe 'cause it's stressed harder. 1370 has lots of power. What kind of hours? after 6000 or so have to be careful of o rings in bottom of sleeves leaking coolant into oil. Powershifts usually O.K. if it works o.k.
scottAR
03-27-2003 18:48:48
I had a yellow 1370 and a white 1570. Both good tractors. Had to put $3000 in the 1370 tranny after 27 years of hard labor and had to put $900 in the injection pump of the 1570 when it was about 25 years old. I don't think anyone makes an implement the 1570 couldn't pull.
Roger
03-27-2003 09:12:27
I've got a 1370, it's 155 hp & the 1570 is 180 hp. Other than that I'm not sure if there is much other difference
