730 Stuck In Fourth
Lee
03-27-2003 14:52:51
I was using my 730 Comfort King on Sunday and it's now stuck in 4th gear (standard transmission - 4 gears, 2 ranges). I had been in gears 1 - 4 and Reverse several times as I was unloading a trailer. Any thoughts or things I should look for? Hoping it's not a major problem, obviously! Thanks for any advice! Lee
scottAR
03-27-2003 18:39:00
 Re: 730 Stuck In Fourth in reply to Lee, 03-27-2003 14:52:51
Is it stuck in 4th only or will the hi-lo range shift? When you shift to high range does it act like it is in two gears? If it shifts to neutral on the range shift and will still move at low range speed you have a bad problem.
