320 Crawler Brake Adjustment
Gene dotson
03-29-2003 15:48:02
I have a 320 crawler and I need to adjust the turning brakes. Haven't found a manual for it. I have adjusted the levers outside the housings. Do I need to remove the rear housing to access the brake adjustment? Any information will be appreciated...Gene
Butch/ OH
03-31-2003 20:07:46
 Re: 320 Crawler Brake Adjustment in reply to Gene dotson, 03-29-2003 15:48:02
As long as your brakes are responding [getting better as you adjust them] to the external adjustment there is no need to adjust them inside. At some point you might notice that the control levers come against something solid and no longer work well to steer the crawler. The band may have worn and the linkage inside hits the top of the housing before the brake tightens around the drum. You will need to drain the differential housing, take the back cover off, and tighten the internal linkage to the brake band.
Gene Dotson
04-01-2003 02:01:15
 Re: Re: 320 Crawler Brake Adjustment in reply to Butch/ OH, 03-31-2003 20:07:46
Thanks Butch;,,This comfirms what I thought. The right brake has almost no stopping power and having to make all left hand turns is getting old...Gene
