580C brake problem
Bill
04-10-1999 16:41:02
The left rear wheel seems to grab in forward and reverse. I tryed backing the adjuster off and there is no change. When I brake with the right wheel it is smooth, when I brake with the left it grabs and sounds like metal to metal. I don't have a service manual, should I get one before doing brake work? Has anyone replace the brakes
that can tell me what to look for. Thanks, Bill
Bill
04-14-1999 03:48:23
 Re: 580C brake problem in reply to Bill, 04-10-1999 16:41:02
Thanks to all for the help, back up and running.
David Davis
04-12-1999 11:03:51
The left side is easier to work on than the right side(Dif-lock).I"ve sold mine but theres 3-4 1/2inch bolts in the housing,after you take them out pull the housing outward.There are 2 brake disc on a splined shaft with a activator between them(its a very simple set up)From here you can change the disc or what ever.There might be a pin or something to remove before you can remove the housing can"t rember but both sides are fairly easy once you get started.
