1030 heads
ME
04-01-2003 18:33:54
Will 1030 diesel heads bolt on the 930 diesel block with out modifications? If there needs to be modifications what do ya need to do? Thanks in advance
bob
04-02-2003 05:31:18
 Re: 1030 heads in reply to ME, 04-01-2003 18:33:54
930 and 1030 take different heads, due tot he different bore size. This makes the bolt pattern off. You can use 730 heads on a 930 and you can use 830 heads on a 1030. Check your casting numbers when looking for heads.
Huh?
04-02-2003 22:57:32
 Re: Re: 1030 heads in reply to bob, 04-02-2003 05:31:18
Bolt pattern is the same. The bigger valves in the 1030 heads would interfere with the sleeve on a 930.
