Case 411B Case O Matic hydraulics
Carl Thompson
04-02-2003 15:51:13
Help
I'm connecting a 3 point concrete mixer to my tractor. It's a single acting cylinder and I've connected it to the remote interlock above the
interlock for the Eagle Hitch. I can power the cylinder fine but when I release pressure to lower
the cylinder it also raises the Eagle Hitch at
the same time. My manual does not cover dual
interlocks. I've got some bleed by going on bit
don't know where.
Carl Thompson
04-07-2003 07:18:06
 Re: Case 411B Case O Matic hydraulics in reply to Carl Thompson, 04-02-2003 15:51:13
Thanks to BLR
I don't have an additional spool. The interlocks
are stacked one over the other and I think they
might be leaking by a gasket or O ring between
the bodies but I hate to tear it apart until
I have an idea of whats going on. I forgot to mention it's a 1959 model.
Thanks
BLR
04-06-2003 22:49:47
Carl,
My grandfather had a 611b with a loader that used single acting cylinders. My recollection is there was an additional valve spool adjacent to the control valve that when moved allowed him to use the loader. What I don't recall is if that valve redirected the 3 point flow to the loader or converted the remote hydraulics. The hydraulic control valve is roughly under the gas tank. Sorry I can't provide better details, but the last time I saw the tractor was 1978.
