530ck case o matic pump
rey
04-03-2003 17:50:56
hello i am replacing a trans pump on my c-o-m i have all the plates off the transmission and was wondering if i need to use any type of gasket cement on the gaskets or just put them on dry?
what type of cement should i use?
is aviation form a gasket ok? or should i use something like form a gasket #2 .
any info would be great
thanks
mEl
04-04-2003 08:01:12
 Re: 530ck case o matic pump in reply to rey, 04-03-2003 17:50:56
40+ yrs at a case dealership as a mechanic, grew up with Case-o's, dry, no sealers are needed if surfaces are clean and dry when put down. mEl
rey
04-04-2003 11:47:39
 Re: Re: 530ck case o matic pump in reply to mEl, 04-04-2003 08:01:12
thanks by the way do you know if the torque converter should be sitting in oil i see that the casting is separated and the oil that goes to the pump is in a different reservoir than the torque converter when i drain the torque converter do i fill up the area around the tc or just fill up the torq conv ?
mEl
04-06-2003 14:28:04
 Re: Re: Re: 530ck case o matic pump in reply to rey, 04-04-2003 11:47:39
Just fill the rear compartment to level and run , keep filling till the level stabilizes.Give it some time as the converter must fill from the rear compartment, I lock the brakes and let the unit idle in high gear and fill to level, that way all motion in the box is frozen, nothing running but the pump, no oil splash to give false readings, someone out there will disagree cause it isnt't in the manual to do it that way, but, oh well!! mEl
Butch/ OH
04-03-2003 19:39:46
Aviation form-a-gasket will work just fine. Whatever you do, don't use silicone. I've seen too many suction screens plugged with that stuff.
