Case 830 propane regulator(Ensign)
Kirk
04-05-2003 06:46:26
I need a rebuild kit or used Ensign regulator for my propane 830 Case tractor.
scottAR
04-06-2003 19:25:34
 Re: Case 830 propane regulator(Ensign) in reply to Kirk, 04-05-2003 06:46:26
If you don't find the suitable repair parts, you can put an Impco regulator on it with the Ensign carb. It works very well and will probably save some fuel over the old leaking Ensign.
jeff
10-08-2003 17:35:24
 Re: Re: Case 830 propane regulator(Ensign) in reply to scottAR, 04-06-2003 19:25:34
Do you know the exact Impco regulator that will work? I will purchase one today if I know.
Thanks
Jeff
Hmmmmmmmm???
04-06-2003 16:27:41
Why You Yelling Kirk? IS The JD Thing A Dig?
Jeff
10-08-2003 17:33:26
 Re: Re: Case 830 propane regulator(Ensign) in reply to Hmmmmmmmm???, 04-06-2003 16:27:41
No Dig, John Deer propane tractors also used Ensign Carburators and regulators. Go to the old dealers that may have old stock.
JP
Roger
04-05-2003 07:51:03
Kirk, you just about have to find a used one, rebuild kits haven't been available for years. My cousin has an 830 that the regulator went bad & we know a guy that has material that he can make diaphragms out of, I don't know what the stuff is or where he gets it, but they put it in my cousins tractor & it works!!! I'm praying my 830 keeps going for many years yet !
John Saeli
04-05-2003 13:38:17
 Re: Re: Case 830 propane regulator(Ensign) in reply to Roger, 04-05-2003 07:51:03
Hey Men; Check with John Deere. A restorer told me he found parts for his CASE LP at a Deere dealer. Hope this helps John
KIRK
04-06-2003 16:20:09
 Re: Re: Re: Case 830 propane regulator(Ensign) in reply to John Saeli, 04-05-2003 13:38:17
THANKS FOR THE INFO. I'LL KEEP GOING WHILE I CAN THEN TRY JOHN DEERE.
