44' CASE DC CLUTCH
DC DON
04-05-2003 15:20:04
NEED HELP GETTING THE RIGHT CLUCH FOR MY DC.
DKase
04-05-2003 19:47:18
 Re: 44' CASE DC CLUTCH in reply to DC DON, 04-05-2003 15:20:04
There was 3 different clutches in them. Do you know which you have?
DC DON
04-06-2003 18:28:45
 Re: Re: 44' CASE DC CLUTCH in reply to DKase, 04-05-2003 19:47:18
I NEED A CLUTCH BRAKE PART NUMBER 2848AA.
DKase
04-06-2003 18:50:46
 Re: Re: Re: 44' CASE DC CLUTCH in reply to DC DON, 04-06-2003 18:28:45
By clutch brake you must be talking about the brake pad in the belt pully. I made my last several from a piece of band brake lining. Counter sink the holes by hand with a drill, and install small brass rivets. Good Luck
DC DON
04-07-2003 07:35:14
 Re: Re: Re: Re: 44' CASE DC CLUTCH in reply to DKase, 04-06-2003 18:50:46
I NEED TO GET THE RIGHT HAND CLUTCH BECAUSE MY DC USED TO BE FOOT CLUTCH BUT WHEN I GOT IT IT HAD A DIFFRENT HAND CLUTCH THEN EVERY OTHER DC I EVER SEEN.
DKase
04-08-2003 06:44:52
 Re: Re: Re: Re: Re: 44' CASE DC CLUTCH in reply to DC DON, 04-07-2003 07:35:14
We will try to get this right yet. The first DC's had the LEVER on the right side of the platform. Later (mid 1941) the lever was moved to the left side of the platform. Internal parts were the same till 1944. Clutches were changed with live PTO in 1951. Changed again with the foot clutch in 53. The DI always had a foot clutch. I was wrong. That makes 5 different clutches. If you would tell me your serial number I would know which one is right for your tractor. Do you need internal parts, or the lever? I'm trying DCase
