380ck clutch
ras
04-06-2003 16:33:46
The clutch on my 1980 380ck should release in two steps - transmission first then pto.It appears that someone installed the transmission clutch spring cups into the inner clutch cover instead of the outer clutch cover resulting in both discs releasing at once.Is this a mistake on some mechanics part or is there an advantage to this.
Elmer
04-06-2003 18:13:37
 Re: 380ck clutch in reply to ras, 04-06-2003 16:33:46
I don't think the cups can be installed in the inner cover. Have you got this apart? I think your problem is the three adjusting screws are in too far.
ras
04-10-2003 08:04:55
 Re: Re: 380ck clutch in reply to Elmer, 04-06-2003 18:13:37
i do not have it apart yet.looking thru the inspection hole the cups are at two different heights.tried adjusting 3 screws. also you cannot feel second step in pedal as per service manual.
