930 clutch and pto sticky
JB Welder
04-06-2003 23:47:53
Has been sitting for a few years and the clutch and pto would not disengage. Just about took out the machine shop wall when it snapped into gear before I realized, smoked the clutch brake too. Backed off both a notch, now clutch OK but PTO still won't stop. Was told clutch was OK before, PTO unknown. Is this from sitting so long? Is it likely to clear up or more serious? Thanks.
DKase
04-07-2003 06:28:59
 Re: 930 clutch and pto sticky in reply to JB Welder, 04-06-2003 23:47:53
Most of the PTO clutches will not come to a complete stop on their own. If they are set up so they will not slip under load the brake (if it has one at all) will not stop it. You can stop the engine and hook up something that has some drag to it, and then start the engine again. The older 930's had no PTO brake at all. Good Luck
John Saeli
04-07-2003 10:53:55
 Re: Re: 930 clutch and pto sticky in reply to DKase, 04-07-2003 06:28:59
Hey D Kase; Are you sure those older 930's had no PTO brake? John
DKase
04-08-2003 04:30:11
 Re: Re: Re: 930 clutch and pto sticky in reply to John Saeli, 04-07-2003 10:53:55
That's right John. No PTO brake on the STD models. I just used most of the parts from one in my 54 DC.
big orange
04-07-2003 18:08:32
John,the older 930's had no pto brake.My standard has always ran under no load,with clutch disengaged.
