Boyce motometer operation or restoration
Kevin
04-09-2003 19:50:19
I have recently purchased a Boyce Motometer to put on my 1929 model C Case. The one that I have looks to have all the mercury to the top. I don't know if this is normal. If it is not normal is there a way to correct this? Maybe it will never work and just be an ornament. Your help is greatly appreciated.
F.T.Snyder
12-10-2004 14:21:09
 Re: Boyce motometer operation or restoration in reply to Kevin, 04-09-2003 19:50:19
If you hold the moto meter in your hand and tap it on a inflated tire gentley the red will go down and than you can use the moto meter as if it was a new one. yours mqafrank I have over a hundard moto moter in my collection and some for sale.
Wayne in Denver
02-17-2004 22:47:20
Sometimes you can put the motometers in the freezer upright for a while to bring down the mercury. Then heat some water and carefully put the bottom in the hot water keeping it upright. This worked for me. If it does work for you, do not let it lie down. Keep it standing upright. If this doesn't work then you are looking for a replacement of the element like I am for another one that I have. So far I have not found the source for the elements.
DON L
04-10-2003 18:40:38
The meter cold. should show no indication at all, if you got it from me , I will replace it at no cost.
Don L.
Kevin
04-11-2003 15:28:50
 Re: Re: Boyce motometer operation or restoration in reply to DON L, 04-10-2003 18:40:38
Thank you for the offer but I did not get it from you. I will be sure not to make that mistake again.
