CC steering problems
Okla/kans Bill
04-12-2003 12:50:15
I far with my grandads 34 CC> I think it has jumped a tooth in the steering as it turns further to the left than right, and I cant keep the right side brake working. How do I adjust this to get it right? thanks
DKase
04-13-2003 09:37:37
 Re: CC steering problems in reply to Okla/kans Bill, 04-12-2003 12:50:15
There should not be a tooth to jump in the steering gear. The stop is on the rear arm that comes out of the gear box. If the stop is cut off the arm goes all the way around. Has the "chicken roost" been modified so it is to short or to long? Or may be that one of the arms has been changed. If you know of another CC you might want to compare parts. I think you will find the problem. For the brakes: They are a band type brake. Pull the cover off and check the linings first. If OK take the slack out of the band and it should be OK. If linings are bad bulk linings of the proper width are available to rivet to the bands. Good Luck
