Case 730 hydraulics
Phillip Womble
04-12-2003 18:29:05
My neighbor wants to sell me his Case 730 CK. The remote hydraulic hookup works just fine, however the lift arms will not go up. It appears that the hydraulic pump is working. Is this a big deal to get repaired? TRANSLATION - would this be expensive to fix?
Chris Reinmann
04-13-2003 11:06:09
 Re: Case 730 hydraulics in reply to Phillip Womble, 04-12-2003 18:29:05
This is easy enough to fix take the seat off and the platform under the seat off , you will see a hydraulic valve. Take it off, take it apart and clean it out be carefull not to mix the parts while taking it apart and putting it back together. The only cost will be couple hours work. The hardest part will be getting the seat off. Hope this helps.
brian in ky
04-13-2003 14:22:22
 Re: Re: Case 730 hydraulics in reply to Chris Reinmann, 04-13-2003 11:06:09
We had to clean a valve in ours but we were able to take the floorboard playe out and get to it without taking the seat off. I think it is the same vale you are talking about.
John Saeli
04-13-2003 10:45:35
It could be as simple as linkage broke all the way to a broken cover housing that has the draft arm cylender cast into it. Probably unliklely, but I've seen it. Hope this helps more than confuses, John
bob in pa
04-12-2003 19:11:16
mine did that to cost me aboot 400 bucks had a shade tree mechanik do it. my problem was a thing that looked like a dog apendage was broke. that aprt was pretty expensive at the case dealer. thats al it needed
