2 930 project tractors $400.00, deal?
Adam Whitson
04-14-2003 11:37:22
I have chance to buy 2 930 diesels for $400.00. both 1966. "Good one" hase foot clutch. Parked becasue of trans clutch isses owner says. Needs rear and front tires (and front rims), no 3 point.
Parts 930, no 3 point, no pto, has cast front wheels. has been some minor parts removed. Niether has the case-0-matic. Looks like cans have been on exhaust, and coolant has been drained, or cracked and leeked out.
Opinions?
ABW
case poor in pa
04-22-2003 16:29:12
 Re: 2 930 project tractors $400.00, deal? in reply to Adam Whitson, 04-14-2003 11:37:22
buy em first then wonder what they are... sometimes you know iffen you snoose you lose
case poor in pa
04-15-2003 16:32:06
hey where they at buddy
Adam
04-16-2003 12:24:38
 Re: Re: 2 930 project tractors $400.00, deal? in reply to case poor in pa, 04-15-2003 16:32:06
Augusta, Kansas
Same place as the Case 500 diesel
ABW
case poor in pa
04-22-2003 16:25:55
 Re: Re: Re: 2 930 project tractors $400.00, deal? in reply to Adam, 04-16-2003 12:24:38
ohhhh kansas ehhhhh? egads drat and double drat
RobertTX
04-15-2003 10:41:11
That sounds like a very good deal to me, I would have a hard time passing it up. Be aware though, that the 930s changed (in 1964 I believe) from the chain drive that was introduced on the L in 1929 to a gear final drive. The earlier 930 would be a 6 speed, the later models are 8 speed. Sounds from your description that those may be one of each and if so, one might not be a back up for the other for any parts in transmission or final drive. I have not worked on these tractors, so am not sure on details of parts interchangeability, but there is a major design difference.
Adam
04-15-2003 16:03:57
 Re: Re: 2 930 project tractors $400.00, deal? in reply to RobertTX, 04-15-2003 10:41:11
Both these tractors have the 6 speed, trans. My 1030 has the 8 speed. They have the one where you bump the stick up and down left and right to get to the right gear. What can I look for to determine if they have the chain drive?
ABW
Bill from up north
04-15-2003 22:47:11
 Re: Re: Re: 2 930 project tractors $400.00, deal? in reply to Adam, 04-15-2003 16:03:57
six speed 930 has slotted bolt holes in the rear axle housings where they bolt to the main rear housing. You loosen the bolts and slide the axles /housings to the rear to tighten the drive chains.
Kennyp
04-14-2003 16:10:18
Better than the stock market for investment if you want to go into the parts business, and have a place to store them. No 3 point is a negitive. Is the tin work good?
