CASE SC CARB
MIKE S
04-14-2003 15:14:20
I'VE REBUILT MY ZENITH CARB ON A 43 SC, AND NOW IT WILL ONLY RUN WITH THE CHOKE A LITTLE MORE THAN HALF WAY CLOSED. THE CARB HAD LOTS OF RUST IN IT, AND I HAD TO REPLACE ALL JETS. I,VE TRIED ADJUSTING IT EVERY WAY I KNOW HOW. ANY HELP WOULD BE APPRECIATED.
Jason KY
04-15-2003 09:10:27
 Re: CASE SC CARB in reply to MIKE S, 04-14-2003 15:14:20
Make sure you have the rubber tube that connects the carb to the air breather installed and that the oil bath is filled with oil. I had the same problem until I installed that rubber tube- now it runs great.
Crispin
04-15-2003 07:49:01
MikeS, Do a search on the Case board using "crispin carb" and look at the post "SC carb tip" 12/4/01. You'll see what happened to me...
Mike Schotte
04-14-2003 15:24:32
Where did you mangage to get new jets? Zenith told me that they were no longer available...
-Schotte
MIKE S
04-16-2003 14:40:38
 Re: Re: CASE SC CARB in reply to Mike Schotte, 04-14-2003 15:24:32
THE JETS WERE NEW OLD STOCK FROM A LOCAL TRACTOR REPAIR SHOP.
Mike Schotte
04-14-2003 15:29:03
Oops- forgot to ask:
Did you check or adjust the float level when you rebuilt the carburetor?
Are you sure that you don't have a pinhole in the float causing it to flood?
-Schotte
MIKE S
04-16-2003 14:44:08
 Re: Re: Re: CASE SC CARB in reply to Mike Schotte, 04-14-2003 15:29:03
I DID CHECK THE FLOAT LEVEL, IT WAS OK. ALSO CHECKED FOR PIN HOLES OK AS WELL.
