12 volt from 6 volt
dave f
04-12-1999 16:14:32
how do i convert my 211-B case over to 12 volt
from 6 volt. What do i replace and what do i keep . my case has a positive ground, do i have
convert to a negative ground?
I guess i want a step by step explanation of how to do it.
thanks
dfoley@kalama.com
David Davis
04-16-1999 09:25:05
 Re: 12 volt from 6 volt in reply to dave f, 04-12-1999 16:14:32
Why convert? By a good high amp 6 volt battery and keep the generator. Cost around $100.00 to rebuild or less depending on what it needs.You"ll put a starter in every couple of years any way running on 12v.A well tuned tractor starts easy,if you have to crank that hard fix the other problems.Dave
TMAC
04-12-1999 18:53:55
Have you looked into the Article Achives? There is something there on this subject. I converted my VAS to 12V. Not hard to do especially if you use an alternator with one wire out. If you use the same coil be sure to use a step-down resistor between it and the battery.
