Tractor split
ken tabor
04-22-2003 18:48:49
I have never split a tractor. I have a 1950 case model D. Need to do some clutch work. Anyone have any advice on what type of equiptment I would need to do the job safely? I have nothing
Ken
Bob
04-22-2003 23:26:54
 Re: tractor split in reply to ken tabor, 04-22-2003 18:48:49
The main 'special tool' you need are the splitting pins. They are 3/4 inch rods, 13 and 13/16 inches long (can be a bit longer) with holes bored though at the ends to take large split pins.
Undo bolts at 3 and 9 oclock positions between engine and transmission, insert pins, undo pipes, control rods etc. Jack under transmission and rolling jack under engine.
Should come apart easily.
Allan C
04-25-2003 20:51:21
 Re: Re: tractor split in reply to Bob, 04-22-2003 23:26:54
Starting with the basics you need a cement floor, a decent floor jack and some blocks. Support the front of the trans with some blocks, Cut a couple of wedge shaped ones or whatever you need to jam between the engine and front axle so the engine won't tip. The rods mentioned in the other post are a good Idea and handy but not strictly necessary. Place the floor jack under the rear of the engine. It may be easiest to place a block between the radius rods and the engine and jack on the radius rods. Go careful and it's not that hard!
