1410 lift
hntndaylight
04-22-2003 19:45:01
Can't seem to get the lift to bleed on a 1410. May have the linkage out of adjustment on the handle. Valve is good, pulled it off a "donor" tractor and it was working fine. Loosen both bleed screws under the plate and pull to bypass,noting happens. Had good hydraulic pressure at the remotes. Cant find a bleed screw on the right side, tractor does have a dump valve.
Thanks in advance!
