10-18 Cross-Mount
Dan in Ore
04-27-2003 06:59:35
I am going to work on a friends 10-18 cross-mount today.
Any tips on getting it started (retarding the spark, choke settings etc.).
Allen
05-01-2003 15:05:10
 Re: 10-18 Cross-Mount in reply to Dan in Ore, 04-27-2003 06:59:35
If it has the factory carb, don't keep cranking and cranking, or you'll fill up the manifold with liquid gas (been there, done that) Use the primer cups instead. Also, don't pull out on the crank while pulling up either, or it will come off, swing up, and crack you one upside the head (wonder how I know that, too)
mwfarm
04-28-2003 23:14:38
Be careful and make sure the timing is set right, or you'll break an arm for sure. These things will bite you before you know it.
