6 Volt Light bulbs
dbb62
04-27-2003 11:48:44
My S has original headlights on it, but both bulbs are burned out.
I checked at NAPA, and was surprised he couldn't find anything.
They are GE 1323 6v bulbs. These can't be that hard to still get.
Where can I find them, I don't have time to run all over town and figured someone here would know who to contact.
Thanks,
Doug
klyde
04-28-2003 21:39:17
 Re: 6 Volt Light bulbs in reply to dbb62, 04-27-2003 11:48:44
are these the bulbs that fit over the 3 pins in the socket/
reflector if they are i think i may have some
dbb62
05-01-2003 09:45:26
 Re: Re: 6 Volt Light bulbs in reply to klyde, 04-28-2003 21:39:17
Yes, that is what they are. If you have some, let me know, I may be able to take them off your hands.
Mike from Canada
04-27-2003 21:51:48
i was able to get 6V bulbs for my VAC @ my local UAP/NAPA store. its just that they wouldnt sell me one or two but a box of ten! @ $50CDN! ($25US). they wont keep a box for themselves so you get to keep an entire store supply for 3 or four lights on your tractor.
the real crummy thing is i have no other options. purchasing one or two bulbs over the 'net is more expensive than buying a box of ten for me and im not going to spend over an hour driving in my car because some farm supply store 80 miles away is willing to give me as many as i want for my tractor at cost.
check w/ NAPA again. they may sell you a box of 10 because they dont want it sitting on the shelf forever when you just want two.
may the force be w/ you
mike
(p.s. mine were WAGNER bulbs if that helps any)
Baggsy
04-27-2003 21:23:52
Somebody refresh my memory here, but either 63's or 67 six volt bulbs will work fine and are about a dime apiece. For that matter a 12 volt bulb will work but won't be quite as bright. Either one will get past the 'correct' police unless they take your lights apart. Better to troubleshoot with too in Case you have a dead short...
dbb62
04-27-2003 12:44:21
Searched the archives. Nobody open today (Sunday), but maybe the bulbman will have some for me. Let me know if you have other ideas.
Thanks,
Doug
vac-va
04-28-2003 06:59:21
 Re: Re: 6 Volt Light bulbs in reply to dbb62, 04-27-2003 12:44:21
Just a suggestion. In my local building supply store,I found two-packs of 1133 bulbs. They are sold as replacements for high intensity lights, 6 volt, 24 watt. Work fine in my vac.
Just
