3pt Hydraulic valve
Bruce
04-28-2003 04:21:34
My 540 3pt control value is not allowing the fluid to flow to the lift cylinder. Is this something a novice can work on? Any comments welcome. Thanks
klyde
04-28-2003 09:36:43
 Re: 3pt Hydraulic valve in reply to Bruce, 04-28-2003 04:21:34
check the roll pin on the valve, it may have worked out thus not moving the spool. have had it happen so often that i finally put a wire through the roll pin to keep it from working out.
