730 question
Mike
04-28-2003 07:19:44
I am having a problem getting the cap off the hydro filler. Is it threaded and needs to be turned off? It is on very tight. Also, what kind of fluid should I use? Thanks.
John Saeli
04-28-2003 19:08:46
 Re: 730 question in reply to Mike, 04-28-2003 07:19:44
Mike; S Heiserman & Landon are correct on that cap coming off hard. Pry it up gently. A good Trans.- Hyd fluid is correct, but I add 85W-140 to it. I've had my 730 since '73 and never touched the drive train. 1/4 part 85W-140 to the fluid adds body to the thin fluid. You wouldn't do it to a power shift tractor. John
SHeiserman
04-28-2003 19:14:33
 Re: Re: 730 question in reply to John Saeli, 04-28-2003 19:08:46
Is that recipie good for C-O-M too?
John Saeli
04-29-2003 04:34:00
 Re: Re: Re: 730 question in reply to SHeiserman, 04-28-2003 19:14:33
Hey S. Heiserman, It's ok for the transmission-final drive, but not in the convertor housing. Them gears would never stop draggin.
SHeiserman
04-29-2003 18:45:53
 Re: Re: Re: Re: 730 question in reply to John Saeli, 04-29-2003 04:34:00
Thanks John. I was thinking trans, hyd, and converter were all common sump. I know after I put Hy-Tran in the tractor, it whined. Whining goes away when clutch is pushed in and I thought maybe your idea would help.
John Saeli
04-30-2003 04:29:37
 Re: Re: Re: Re: Re: 730 question in reply to SHeiserman, 04-29-2003 18:45:53
I'm not sure if the Comfort Kings used a common sump. I 'm sure the older ones didn't, but I could be wrong.
SHeiserman
04-28-2003 18:59:43
My cap comes off hard too. The fluid a CASEIH dealer will sell you for that is Hy-Tran Ultra.
Landon
04-28-2003 12:36:06
i believe it has the same kind of cap as the 930 and 1030(they are not threaded and are vented on the under side)is it on the left hand side facing the rear end of the tractor? ours on our 1030s are hard to get off, we usually have to pry them off,i also changed the hydraulic fluid in one of our 1030s last year. i went to the case ih and bought the fluid they run in the new tractors and put that in it.
