630 case no down pressure on 3 point hitch
Mark
05-04-2003 15:46:09
I have bought what i think to be a 1963 Case. 630 Series model 641. the three point hitch lifts up fine but when i push the lever down it acts like it is in float . Is that normal ? Any response would be greatly appreciated. The local case delear can not help.
scottAR
05-04-2003 16:16:13
 Re: 630 case no down pressure on 3 point hitch in reply to Mark, 05-04-2003 15:46:09
I've never had a 630, but a 530 only had a one way cylinder on the rockshaft. It uses the implement weight to go down. If you don't have a load on the hitch it might be slow going down if the seals on the rockshaft piston are in good condition and the oil is cold.
John Saeli
05-04-2003 18:18:46
 Re: Re: 630 case no down pressure on 3 point hitch in reply to scottAR, 05-04-2003 16:16:13
The only 3 PT. Hitch to have down pressure was the Eagle Hitch on the Racine tractors with the external cylender. The 630 had no down pressure.
