Bleeding case 530CK fuel system
unclebear
05-06-2003 21:21:09
we have a older case 530ck deisel backhoe that was here when we got our property. we can get it to start and run for about 30 seconds then it dies. i belive we need to bleed the fuel system. if some one could tell me the process it would be very helpful.
unclebear
05-08-2003 10:11:40
 Re: bleeding case 530CK fuel system in reply to unclebear, 05-06-2003 21:21:09
well i didnt get a response but i sure did figure out a great way to bleed the fuel system. i took a old inner tube cut a 5 inch circle around the stem then used a large hose clamp and fitted it around the fill tube for the fuel tank. pumped that with a bicycle pump and soon had pure deisel flowing out of the bleeder screws in seconds. tractor is running like a champ!!!
