Case Leaky Swing Ram
brent
05-10-2003 12:34:20
I have a Case 580 Super E with a leaky backhoe swing ram.
Any tips or tricks for getting the backhoe out of the way to remove the ram?
Also, do I need to completely remove the cylinder or can I just pull the ram right out the front of the cylinder?
Marc
05-10-2003 14:49:10
 Re: Case Leaky Swing Ram in reply to brent, 05-10-2003 12:34:20
Brent,
You don't have to remove the cylinder from the swing trunion. Swing the backhoe all the way to the oposite side of the cylinder you want to re-seal. Then remove the pin at the cylinder rod end then unscrew the cylinder gland to remove the cylinder rod, gland & piston. When re-assembling the piston to the rod be sure you use red lok-tite #271 on the bolt threads.
Hope this helps, Marc
Brent
05-10-2003 16:58:30
 Re: Re: Case Leaky Swing Ram in reply to Marc, 05-10-2003 14:49:10
Marc,
Thanks for the reply.
One more thing. The number stamped on both glands is G103773717812.
Case tractor parts web sites I have checked said I need this number to get the right seal kit. However, I can't find any online sites that have my part number listed.
I understand that the G10 at the front of the number means I have a one part piston as opposed to the "split piston."
Do you think that a parts dealer will be able to use my number or is there another place on the cylinder to check?
