Case 600, Bad transmission noise
Rick in MD
05-12-2003 09:57:47
I have growling like sound coming from the transmission in anygear or out of gear and the clutch in whith the belt pully turning. Does anyone know were in the transmission this noise is coming from? I use this tractor alot on the sawmill and pulling a five bottom plow.
Jim P
05-12-2003 22:23:04
 Re: Case 600, Bad transmission noise in reply to Rick in MD, 05-12-2003 09:57:47
It sounds like the bearing on the input shaft(from clutch to the first cross shaft). If bad it will than make noise whenever the engine is running. You say you use it on a saw mill. Do you use the pto much or sit idling much. If you use the pto or idle very long you must engage the clutch. If you don't the input bearing will go dry and burn out. It happened to me on a 1960 930.
Rick IN md
05-13-2003 05:39:21
 Re: Re: Case 600, Bad transmission noise in reply to Jim P, 05-12-2003 22:23:04
It only makes noise when the clutch is engaged. I use the belt pully to run the saw mill.
John Saeli
05-12-2003 10:20:17
Rick; Don't sound good, sounds like the ring & pinion, AKA clutch shaft, or input shaft.
