Case 446 w/ Onan 16 Hp
Ray
05-12-2003 10:10:11
The engine in this Case 446 tractor quite suddenly stopped acting as if it had almost seized. It backfires out the exhaust when I crank it. I've checked the compression and found one cylinder w/ 130 psi and the other only 30 psi. I don't see anything wrong with the piston, valves, or head gasket. Does anyone know if a timing problem could the problem? If so, how do I go about finding out?
John Saeli
05-12-2003 10:17:58
 Re: Case 446 w/ Onan 16 Hp in reply to Ray, 05-12-2003 10:10:11
Ray; Our 446 acted the same way, when I tore it apart I found a broken camshaft.
if
05-13-2003 10:17:03
 Re: Re: Case 446 w/ Onan 16 Hp in reply to John Saeli, 05-12-2003 10:17:58
If the points run off the end of the camshaft, and the camshaft is broken, how can the engine run at all????
AllanC
05-16-2003 20:58:07
 Re: Re: Re: Case 446 w/ Onan 16 Hp in reply to if , 05-13-2003 10:17:03
You may just have a valve keeper fallen off. I'm no Onan expert but I've seen this on other small engines.
