870 relief pressure
Adam
05-13-2003 21:00:31
Is there any reasons why I couldnt set my relief valve the same as 10 or 1170. As far as I know the hyd pumps are the same. I would like to put a loader on my 870, but I dont think 1300 psi will lift much. Thank you.
RoyG
05-14-2003 05:32:59
 Re: 870 relief pressure in reply to Adam, 05-13-2003 21:00:31
Don't go above 2150 and you should not have any problems with any of the hydrolic system componets. the only thing that could cause any problems is the three point lift system if you overload it
