41 SC Polarity
Don K. From Pa.
05-14-2003 15:30:34
I have a 41 SC that the original owners manual says to hook up the negative terminal of the battery to ground. Is this correct? I thought all the old six volt systems were positive ground. It runs either way but I have the generator unhooked so it would not get damaged.Also, the manual talks about a "field resistor" for the two stage regulator.Where can I get one to go with a cut out? The tractor is in original condition except for a Delco-Remy distributor and 3 5/8" pistons. Thanks for your help.
D Smoker
05-14-2003 15:42:45
 Re: 41 SC Polarity in reply to Don K. From Pa., 05-14-2003 15:30:34
The SC's have a negative ground system. Don't know about the resistor, doesn't mention one in my SI manual.
