Case 580 Construction King
A.J.
05-16-2003 09:04:17
I have a case 580, early 70's that I recently purchased. I noticed that the water pump was bad and needed to be replaced. I am about to take a crack at it this weekend and was wondering if this is going to be a difficult project. I think I can get the fan, pulley and pump off without removing the radiator - am I right? The parts place where I bought the water pump said I had a 50/50 chance that it was the right water pump. He said that the size of the propeller on the pump would be the difference. If the old pump has a smaller propeller - would it really matter if I replaced it with a pump that has a larger propeller?
Thanks in advance!
G.Mclean
07-07-2003 23:26:07
 Re: Case 580 Construction King in reply to A.J., 05-16-2003 09:04:17
Sorry, I have the same problem;my master mechanic says no.My problem is transmission.Thanks for your reply.Keep in touch.Location?Price as is.Don't have serial#.Will get back to you.Calling from Pr. George B.C. Get Back.My Great Granddaughter is doing me modern technology.
Alyssa/Fernie.O
DaleIN
05-16-2003 12:49:28
AJ, if you have the diesel, all the impellers are the same. The 159 gas engines sometimes use different impellers in different applications, and sometimes that extra 1/8" will keep it from going into the housing.
Its been a long time since I turned a wrench, but as I recall, it can be done with the rad installed...but it IS a knuckle skinner.
