Brakes Case 930 CK diesel
David
05-17-2003 04:05:37
I have a Case 930 CK diesel. The brakes on the tractor are not working at all. Where do I start? And how? I like to have them fixed. Is there any adjustments that I need to do?
Thanks for all the imput in advance.
Jim Handke
05-17-2003 19:27:46
 Re: Brakes Case 930 CK diesel in reply to David, 05-17-2003 04:05:37
There is a nut on the brake rod that sticks out of the brake housing. Turn that nut clockwise until the pedals go down about a third of the way. If you still don't have any brakes, you must replace the brake pads. If the tractor sits outside a lot, you probably have rust built up inside the housing. That ruins the pads quickly.
