1070 hydraulic leak
robert shealy
05-17-2003 17:44:38
What would cause hydraulic fluid to pour out the starter of a Case 1070? It leaks at least a gallon in just a few minutes. Could it be coming from the transmission?
turbo
05-17-2003 20:33:12
 Re: 1070 hydraulic leak in reply to robert shealy, 05-17-2003 17:44:38
There is also an oil seal in the middle of starter.
Robert Shealy
05-18-2003 07:47:14
 Re: Re: 1070 hydraulic leak in reply to turbo, 05-17-2003 20:33:12
Wow! I was about to get started with a transmission teardown! This is the first time I have seen such an arrangement. Thanks, Turbo and Jim!
Jim Handke
05-17-2003 19:15:08
70 series tractors with powershift transmissions have trans. fluid in the flywheel compartment. There should be a gasket between the starter and housing. It sounds like your gasket is missing or defective.
