1 more DC case 3point question for Mike Schotte
Dave_D
05-19-2003 12:15:42
On your SC case 3point conversion, did you have to remove the drawbar? I am hoping to find a way to keep the drawbar and have the 3point too.
Thanks
- Dave
Bob
05-20-2003 09:39:59
 Re: 1 more DC case 3point question for Mike Schotte in reply to Dave_D, 05-19-2003 12:15:42
The drawbar on my 43 SC is adjustable- so if yours is made the same way and is in the extended position- it can be shortened. When using my motor lift bail with a chain through the holes, the chain will not interfere with the drawbar as the bail arms go up and down.
I am now adding live hydraulics to my SC- the next step will be to use a hydraulic cylinder to raise and lower the lifting bail and to weld extensions onto the the bail "arms" to widen them to 28"- which I think is standard for cat 1. One of the arms will have a bolt on bracket that will have to be removed and installed each time a new implement is connected to the lower arms. That is my plan anyway- and I plan to leave my drawbar in place.
If I get it working I'll post pics.
Dave_D
05-22-2003 15:18:07
 Re: Re: 1 more DC case 3point question for Mike Sc in reply to Bob, 05-20-2003 09:39:59
Bob, if your draw bar can be retracted, then you can setup your 3 point like Mike has setup. He has some pictures.
Mike Schotte
05-19-2003 14:16:23
Dave-
They drawbar was already missing in action when we got the tractor in '84. My Dad welded a second toplink connection point onto the drawbar support for use with a box blade.
That's pretty non-removable. I just got replacement drawbar, support & lifting bail a few months ago in case I ever want to go back to original.
That drawbar is a BEAST. Much heavier than it looks.
To answer your question- the arm extension on the lifting bail would probably clear the drawbar if it had been left in place.
-Schotte
Dave_D
05-20-2003 07:47:58
 Re: Re: 1 more DC case 3point question for Mike Schotte in reply to Mike Schotte, 05-19-2003 14:16:23
Mike.
On my dc, if I run a bar between the holes of the lifting bail it would hit the draw bar. Oh well - time to creative.
Thanks again! :)
- Dave
Mike Schotte
05-20-2003 09:02:54
 Re: Re: Re: 1 more DC case 3point question for Mike Schotte in reply to Dave_D, 05-20-2003 07:47:58
Good point- I forgot about the "connecting" bar I have to hold the lift arm extensions onto the bail arms.
Let me know what you come up with.
