Case 680e hydrolics quit working
don
05-20-2003 06:27:01
I have posted the same message in tractor talk.
I was using the front loader when suddenly I had no pressure. All hydrolics stopped. There is fluid in the tank. There is no new or large leak. There were no funny noises, smoke or any other noticable changes. The bucket just stopped going up, it took me a few seconds to realize that the steering also has quit and a quick check revealed all hydrolics were gone. It still runs and shifts fine.
Have I blown the pump? I need this thing working but I can't afford a big fix. If there is a reasonable fix, I'll pay a guy to start tearing it down, otherwise I may need to sell it for parts.
Any ideas? A rough idea of what repairs may run will help me decide what to do.
jimks
05-20-2003 10:53:54
 Re: case 680e hydrolics quit working in reply to don, 05-20-2003 06:27:01
If you've suddenly lost all hydraulic functions, check your pump coupler and see if the splines are stripped... or maybe the pump shaft is broken. If this is set up like a 680D, and it probably is, it has a short shaft maybe 3" long in the pump that couples the pump drive coupler with the gear shaft in the pump. That shaft can be replaced separately from the main gear shaft and isn't that expensive... might get by with that shaft and the coupler.
don
05-20-2003 20:11:49
 Re: Re: case 680e hydrolics quit working in reply to jimks, 05-20-2003 10:53:54
The pump bolts has worked loose. Now fixed, thanks for the help.
