1070 hyd. problems
Ben
05-20-2003 19:49:13
Does a 1070 have more than 1 hyd. pump i have 2 1070's one will not lift the 3pt and wont lift any impliments using the hyd. outlets is the pump out? The other one has hyd. preasure out one outlet but wont let the fluid return is this a stuck valve in the hyd. bank? How hard is it to replace the pump? Also the tractor with no preasure wont move in the 2nd or 3rd power shift gear but works fine in first will it damage the trans. to keep running it like this and how is it fixed? Thanks
fire chief
05-30-2003 19:49:47
 Re: 1070 hyd. problems in reply to Ben, 05-20-2003 19:49:13
start your tractor let it worm up a bit, leave transmission in neutral and shift thru your powershift. Go from 1st to second,,,second to 3rd then 3rd to second,,,second to first. Do all of this at an idle, Inbetween shifts watch the transmission pressure gauge. while shifting between ranges wait a bit and watch your gauge. It should move to the left for a second then recover . I will be waiting to hear your result.
also the hydraulic pump is located on the back of the rear end housing above the pto shaft. You should see to levers that rods hook up to ,,the pump is behind that plate.
Larry
05-20-2003 22:30:11
Hydraulic pump is bolted onto the back of the trans/diff above the pto.
