Case 1030 pto
Robin
05-22-2003 18:58:29
Have Case 1030 tractor with 1000rpm pto.Want to change over to 540rpm.What parts will I need,and where can I find them?
flyingvranch
05-24-2003 15:38:30
 Re: Case 1030 pto in reply to Robin, 05-22-2003 18:58:29
I'm not sure about your 1030, but on my 1070 you simply remove a large snap ring around the shaft, pull it out and turn it around and push it back in and replace the snap ring. It will engage a different set of gears and change to either speed. You might give that a try before buying parts. Good luck!
Jim Handke
05-26-2003 19:38:16
 Re: Re: Case 1030 pto in reply to flyingvranch, 05-24-2003 15:38:30
The 30 series were not equipped with that arrangement. Only 70 series on up.
Jim Handke
05-24-2003 09:46:45
All gears and output shaft will have to be replaced. Contact elmer or brian at parts@elmersrepair.com. They part out case tractors and ship all over the country.
